Disconnecting aerial, power etc. Can't retune as menu facility is disabled both on remote and TV.
Try a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Testimonial: "Thank you Knight for your swift response. I have disconnected TV from mains and will leave overnight and report tomorrow (I am in Australia)."
