TOSHIBA SATELLITE L55..... I ALSO CAME UPON OPTIONS IN TROUBLESHOOT 1 REFRESH 2 RESET 3 ADVANCED OPTS. IN ADVANCED OPTS 1 SYS RESTORE 2 SYST3EM IMAGE RECOVERY 3 STARTUP REPAIR 4 COMMAND PROMPT 5 USFI FIRMWARE SETTINGS 6 STARTUP SETTINGS in startup settings; ENABLE BOOT LOGGING DISABLE DRIVER SIG ENF and stuff like that.
It depends on what you are trying to do. If you want to wipe the harddrive before selling, overwrite all partitions. This will cause everything on the drive to disappear. BE AWARE that with the correct software, that information is still there. If you are having problems booting, run startup repair. Refresh should fix corrupted files, system restore will return unit to new condition, all data lost in this case as well.
Testimonial: "excellent, thank you so mmuch"
Will windows reinstall in either case? THAT was my worry
dont care about the data
A system restore will set the system back to out of box which would be with Windows installed.
SOURCE: windows xp home edition startup problem
One of these; Esc & F10, will give you access to the BIOS settings that are stored in a bit of memory (CMOS) that the system reads at turn-on.
You will get a text-only screen with a number of function selections which can vary widely so look at them all without making any changes (arrow keys and Enter selects) to see if the feature that is causing you to choose at every boot is a BIOS setting.
All BIOS seem to offer a 'Save and exit' or a 'Exit without saving changes' type of choice so if you find none that logically could be altered to avoid going through those menus each time, you can return to your undesired condition without messing up anything.
Also typically present in BIOS is a choice that read something like 'Return to factory defaults' which will automatically change the setup to something safe and that which most users want.
If you choose that one, then you need to choose the 'Save and exit' selection.
The reason for those steps is to allow those who use a Unix-based (or other) alternative operating system for some tasks to choose different boot modes.
SOURCE: Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
SOURCE: Hi I have a fujitsu amilo pi 1536 laptop and wish
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
SOURCE: Came back to house and
Download and burn your Windows 7 Recovery Disc..The Windows 7 Recovery Disc can be used to access a system recovery menu, giving you options of using System Restore, Complete PC Backup, automated system repair, and a command-line prompt for manual advanced recovery.
Instructions >>>
Windows 7 32 bit Repair Disk
Windows 7 64-bit Repair Disc
1.Download the appropriate .torrent file from above that corresponds to the version of Windows 7 you have installed.
2.Download and run µTorrent.
3.Open the .torrent file you downloaded with µTorrent. (File -> Add Torrent)
4.Select where you want µTorrent to save the 7 Recovery Disc.
5.Wait for it to download.
6.Burn the .iso file that µTorrent downloaded to a CD using these instructions.
When you want to use the recovery center, put the CD in your drive and boot from it. This is usually done by pressing F8 at startup, or changing the boot drive order in the BIOS.Repair Windows 7 using Startup Repair Tool.
