There might be something wrong with the Blu-ray laser, you might consult with a technician or contact the manufacturer for tech support. And remember to check the region code on your discs and see if it matches the code on your Blu-ray player. If the region codes don't match, the discs won't play. You can make region-free copies of your Blu-ray discs with a program called Leawo Blu-ray Copy. Here's how to make region-free Blu-ray copies: How to Make 1 1 Disc to Disc Blu ray Backup with 1 Click Blu ray Copy...
SOURCE: Our Sony Blu-Ray BDP-S300 will play older Blu Ray
Try to update the firmware on the player by going to this website http://www.blu-ray.com/firmware/firmware.php?id=10 the newest version is 5.20 fixes alot of problems including playback issues with some BD movies and safe the file into a flash drive and plug it in on the back USB port, go to menu/firmware update run the update.
SOURCE: Some blu-ray disks play on the sony bdp-s300 and
Cause walmart has parental discs. Some sort of censorship version. All there music cds delete or beep/blip the profanity out, so im pretty sure they get their movies with a certain level of parental control embedded. Make sure your parental control level on the sone BD player if set to play all. Basically no parental regional restrictions. Hope that help. If that doesnt. I suggest just not supporting Wal-Mart. They are NWO associated. And everything you buy there no matter hw insignificant have RFiDs embedded into them. Just a little FYI for ya. Google it. Its creepy stuff.
SOURCE: blu ray disk wont play.
this could be a failure in the processing secttion of the card. since this is only months old it is important that you take this for warranty claims and get the immediate attention. It could be also expensive if it is out of warranty, possible failure of the proccs board.
SOURCE: My LG BD 300 Blu Ray Player will no longer play
a weakened laser will do this sorry to hear your problem its good you have already done minor troubleshooting to diagnose this but i would suggest a cleaning disc before any further actions hopefully this is helpful and good luck:)
SOURCE: Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
