Taken down and vacumned debris/dust from unit. It recently would start heating after 15 minutes in on position. Currently will not go further than heating the coils.
SOURCE: quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
SOURCE: Maytag MDG16CSBWW heating problem
HI thanks for the question. well ,you changed all the parts you needed to. but clean the venting from back, to the outside. thanks. please rate my answer. thanks.
SOURCE: My unit runs for 10 to 15 minutes and turning off.
when i turn the dryer on and push start it does not always start - have to jiggle the temperatur bottom push start and back and forth and then it will go on what is wrong?
SOURCE: Replaced thermal fuse, and gas valve coils, now no heat at all!
Replace the glow bar ignitor.
SOURCE: maytag gas dryer will heat for about one minute
The gas coils on the gas valve have gone bad. These are located on the gas valve and will be 2 solenoids. Replace them both and should be able to get as a set. 12001349 should be the number and cost less than 60.00 for the set. Good luck and thank you for using Fix Ya.
