My Memorex Karaoke machine model # MKS2420NBL worked fine until I changed the CD now it won't play and the display just shows 2 lines like there is no CD in it. What happened?
I've unplugged it and plugged it back in, turned it off and back on, tried multiple CD G's, cleaned the CD's, and still nothing.
Re: My Memorex Karaoke machine model # MKS2420NBL worked...
You changed the player CD or the lens of the player . if you replaced the lenses check whether you attached the white ribbon data cable probably. at the same time check out whether is worn out .....
Won't play ITunes! This Karaoke is incompatible for Apple (ITUNES, IPOD, etc.) I even tried creating Thumb Drive (using USB) and then a CD. This brand Karaoke won't play the ITUNES songs.
:((( Very frustrated
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files. Karaoke Builder
You MUST use a special Karaoke CD disk to show lyrics on the screen. Plain music CD's will play music but NOT display the lyrics. Karaoke disks can be expensive... so shop online for Karaoke CD's. Some music stores, including Costco and other warehouses sell some Karaoke disks, but they are usually in a very small section of the displays.
Had same problem opened up back found blown fuse replaced and still blows.
Unhooked power source from were fuse was blown and fuse dose not blow seems to be something in that big board above it.I'm realy not into repairing of electronic boards. There is a lot or stuff going on inside there.
I work for Memorex tech support. Our number is 800-919-3647.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your karaoke machine needs to be repaired.
There is a part that has developed a defect and needs to be replaced. The problem is Memorex no longer stocks replacement parts for most of their electronics. If your unit is under warranty, it will be replaced by the company. If it is out of warranty, please call the above number to see if your model qualifies for any out of warranty exchange options.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
