Cleaned the filter on check valve and reset the breaker but not working
SOURCE: Where do I find the reset button on the Stiebel
On the Tempra 29 there is a "safety thermal cut-out" on the top of each of the heating elements within the box. I have had to open it up before to push the breaker. They are a small red plastic push button on the top. Carefully press the braker button without touching the electrical wiring inside. I hope that works for you.
SOURCE: how can I reset the safety thermal cut out from my
the diagram on this page shows the safety thermal cut-off on top of the heating vessel on the right, inside the unit, remember to electrically isolate before opening.http://www.tanklesswaterheaters.com/tempra12.html
SOURCE: I am a homeowner and
The reset button is kicking out because the themostat is not....The reset is a safety switch so to speak. It is there to turn off the element incase the thermostat does not. I nrare situations the reset can go bad and kick at too low of a temperature, but usually not.To check out what is actually happening you will need to replace the t-sta and see what happens or sit there with an electric meter and monitor what happens in what order, very time consuming...
My recommendation would be to just change the t-stat and rest bot at once and you will be good again.
heatman101
SOURCE: Stiebel Eltron tankless 24. Problem:No hot
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
SOURCE: what s de minimum working pressure for a tempra
The manual says a MAX of 150 PSI but are you possibly asking the minimum water flow to activate the unit? If so it is .58 GPM or 2.2 l/min.
