Android Ainol Novo 7 Paladin First 4.0 Tablet PC 7 Inch 8GB 1080P Bla Logo
R
Robert Jessup Posted on Jan 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lock button on my Ainol Novo 7 Paladin Tablet refuses to unlock the touch screen when pressed
I have tried pressing the + volume & the on button then releasing the on button when the icon appears, which should show a menu that you can go through to do a factory reset, but that did not work, which was suggested by one of the helpers on your site. I'm sure that the Tablet is Ok, it charges, the time is working, when it is on and press the M button the icons appear but because the touch screen is locked I can't get started, very frustrating when the lock button is on the screen and it won't unlock for me, I have tried other combination button presses with no luck ???
afaq2000ccc
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 54 Answers
  • Posted on Dec 05, 2015
afaq2000ccc
Expert
Level 2:
New Friend:
Greenhorn:
Answers
54
Questions
0
Helped
9265
Points
167
Power port needs repaired
Are you sure it is the port that needs fixed, or is it your usb cord you plug into? If it is the port you need to send the tablet in for a technition to repair. First try a new charger or usb cord and see if it works.
1helpful
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
How can I unlock my tablet ? because I locked my self out
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Acer iconia a500 tablet freezes at the boot screen and does not go any further
The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With the Volume up button held, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release the Volume up button and stop switching the touch screen lock switch once the "Erasing Userdata..." message appears in the upper left corner of the screen.
6.Once the factory reset has been completed your tablet will load to the Welcome screen. 7.Your Factory Data Reset has completed now follow the onscreen steps to setup your tablet."
Good Luck!
1helpful
My acer iconia android tablet refuses to startup
Perform a Factory Data Reset of Acer ICONIA
The following steps will erase all of your personal information, all stored contacts and any programs you have installed on your tablet.1.Power off the tablet.
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
4helpful
3answers
try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
Top Android Tablets & eReaders Experts
Alison Lofts
Alison Lofts
August Brown
August Brown
Antonios
Antonios
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
