No power to panel, Stopped mid cycle and will not turn on now
I have a gwl 08 washer with the same problem-the evacuation pump got wet from a leak and shorted the fuse at the control module(try finding an 8amp slow blow 120 volt glass fuse-virtually impossible),Fisher P says even the module is now deleted from their inventory of spare parts.The fuse(s) is clearly visible when you open the controller where you push the buttons on the face of the washer,
Mike M
You will have to check the power from power supply to relay to control panel. You can check for voltage with multi-tester or voltmeter
