Ovens Logo
k
karen stenning Posted on Jan 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
Blanco oven bso 422w..turned off all knobs and the light c still illuminates on
KATHRYN SMITH
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 92 Answers
  • Posted on Feb 03, 2015
KATHRYN SMITH
Expert
Level 2:
New Friend:
Cheetah:
Answers
92
Questions
Helped
36182
Points
207
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
3 Related Answers
Anonymous
  • 1340 Answers
  • Posted on Aug 17, 2010
SOURCE: Oven starts baking OK but will not stay hot.
This sounds like the heat sensor probe.If you open your oven,look at the back wall near the top.There should be a piece if metal clamped there.When you start your oven,the click is the on switch telling a relay to turn on power.After it gets to the certain temperature,the probe tells the relay to cut power.When you restart the oven after it's warm and cooling down,the sensor probe is giving the relay a "false" hot reading and the relay turns it off.Since it cycles only once or twice,the probe probably gets "stuck".Is the second cycle real short?Good luck! Greg
Anonymous
  • 250 Answers
  • Posted on Nov 27, 2010
SOURCE: Stoves 720 EF Electric Double Oven Model No
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
gcom878
George Gillespie
  • 35 Answers
  • Posted on Mar 18, 2014
SOURCE: oven not working
Gas stove check gas oven safety value
Blanco oven. Clock working. Light not working. Oven not coming on at all. Knob is very stiff to turn back anti clockwise but ok clockwise.
If it is electric model, wear rubberized gloves and give it a good shellacking with a sledge hammer. If it is a gas model, be careful -- you do NOT want to blow up your house!
1helpful
Hi The pilot light when out and the oven has stop working does the pilot light double as a fuse ?? BSO 6000
No. The pilot light uses a thermocouple(safety device) to let the main gas valve know that the pilot is lit so that the main gas valve can operate safely by not letting the main gas valve turn on without a lit pilot light. This way, in no way can the main gas valve turn on until the heat from the pilot light causes the thermocouple to produce an electrical current which allows the main gas valve to operate when the thermostat switch closes.
Nov 22, 2015 • Ovens
Oven not working
1helpful
User Manual Blanco Oven BSO 402w
heres a link to free manual site that has Blanco books Results 1 13 of 13
May 29, 2013 • Ovens
3answers
Unable to remove blown Blanco oven light bulb-stuck fast
I boiled the kettle, added the hot water to a tray and placed it in the oven, shut the door then left it for 10 minutes so it steams up the oven (make sure power is off first). Do the same again. Then get a multi grip spanner and place a kitchen rag over the cover and turn to the left. It does take a bit of force depending on how stiff it is, but the steam will loosen the cover. The steam also cleans the oven quite a bit too!!
How do we make the oven work?
Have a look 1/2 way down this page: http://www.blanco-australia.com/Blanco-User-Manuals.html BCG95W and others are listed. Regards.
May 25, 2010 • Ovens
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 • Ovens
Top Blanco Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Blanco Oven Expert? Answer questions, earn points and help others
