New batteries, wd4o , resetting code
SOURCE: the kids locked the bathroom door and closed it... my
if not a key hole stick small screwdriver or any small flat devise into handle and turn will unlock passive door handle
SOURCE: I have a keyless weiser deadbolt. Can't find any
Very common for the keypad to stop working.
check
that the keypad is not defective. You can disconnect the batteries and
then unplug the keypad. Now put the batteries in without the keypad
connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
SOURCE: how do you reset all the codes on a weiser lock?
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
The instructions for reprogramming the code can be found there. Good luck!!
SOURCE: Weiser keypad deadbolt lock deadbolt does not move
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
SOURCE: we are trying to reset
Good lock
Good unlock
