I have recently shifted to windows system from MacBook Air. I have started using Windows Outlook 2013 and still have thousands of my emails in Entourage 2008 in mac. I have exported all the data into a single .rge file but dont know how to import this file in Windows Outlook 2013. Can anyone help me out here??
As you have mentioned in your problem that you have entourage archived .rge files that you need to import into windows outlook, well that not an easy task to do manually. You will need to convert the .rge format into .pst that is imported by Windows Outlook. And this conversion process can only be achieved with the help of mail converters available online in abundance.
The application I find accurate for this conversion is Entourage to PST Convert Entourage Emails to Windows Outlook PST Entourage...
I hope this helps.
Testimonial: "Used Entourae to pst converter to convert entourage emails to outlook format, did imort them successfully. A very productive application, "Entourage to pst converter" Thanks for the link"
Http://entouragetopst.com/how-to-convert-entourage-archive-rge-files-to-pst-file-outlook-windows/
There are similar threads online for Moving Mac Entourage to Outlook in Windows, a couple of them are listed below, have a look:-
I have simple and direct solution to move the Entourage data files into Outlook Windows easily. You can take help of the data migration like Softaken Entourage to Outlook Converter Software it will give you great solution to move the data files in few steps to get more details you can refer here:- https://www.softaken.com/entourage-to-outlook-converter
Using Kernel for MBOX to PST Conversion Tool you can easily export your Entourage mails to MS Outlook pst successfully. Go to http://www.mboxtopstfile.com and http://www.convert.mboxconverter.net to know more about the application.
If you are searching easy to usage tool that relaxed to use and move all emails then so as per my view an advance resolution that faultlessly fit on this situation is MBOX to PST Online that wholly popular to give its superlative services to change your MBOX file in legible mode after that convert MBOX to PST with emails properties. Read more vital information:-
https://www.sametools.com/convert/mbox/
