Powers on displays logo then goes black, sound is functional, an image can be seen if i shine a flashlight at an angle onto the screen. occasionally the tv tries to reboot shuts off then comes back on to do the same as i described above.
Unfortunately you have a bad panel. If the TV is out of warranty then it would be to expensive to repair. A bad panel catastrophic. Sorry for the bad news :(
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Testimonial: "Thank you for the input. I don't think it would be the panel because as in the description when i turn it on at first it boots up displays the logo perfectly fine then goes dark. I've ruled out power supply board so that leaves main board which i already had to replace once or the tcon or inverter."
If your screen is black but an image can be seen against bright light then your backlight / inverter is bad and needs to be replaced.
