Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
• 0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
• 1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
