Question about Coby Tablets & eReaders
I reset my coby kyros mid8042-4 but when i tirned it on the original app selection was not there it will not download getjar so is basicly useless as i can get no apps
I btried to reset twice with same result the reason i was doing the rest is i tried to delete e books from ub reader it would delete them but when i tried to add new ebooks from sd card it would reload books i had deleted and that were NOT on the sd card i was worried about internal memory and confused so decided to start over i loved this unit until then
4 Suggested Answers
6ya staff
SOURCE:
stealthnh
  • 62 Answers
SOURCE: I try to download apps
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
Posted on Apr 22, 2011
charles0285
Charles Williams
  • 160 Answers
SOURCE: How to download free app for adobe reader
Adobe reader can be added fom app store.Click app store,bottom of screen choose categories.In search box at top type adobe reader and under ipad apps tap free to download.
Posted on May 22, 2012
TechyDrood
Justin
  • 2072 Answers
SOURCE: The App Store won't let me download anything on my tablet. I am using getjar because that is what works on my tablet. How do I fix the App Store on my coby kyros tablet?
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
Posted on Nov 27, 2012
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
My coby kyros 8048 won't conncet to the internet after factory reset
Depends on the Android version you have on.
But commonly:
Settings (the pinion icon) > Wireless and networks > Wi-Fi setting (On). Then you select your wireless point and enter password.
Hope this helps.
May 14, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
How to use video call to my coby kyros
Download and install an app called "tango"
Apr 06, 2013 | Coby Kyros 716829701508 Tablet PC
Why can I no longer access my Amazon Kindle App on my Coby Kyros tablet?
Coby no longer uses GetJar, I would download 1mobile.com's - http://www.1mobile.com they have an app store that has an updated version of Amazon App Store.
Apr 05, 2013 | Coby kyros Tablets & eReaders
How to install google play on my coby kyros mid 7035?
Well, as far as I know, there is no way to install it on your Android device.
Unless you have rooted your device. And here is how you can root your Coby Kyros.
Note: rooting is 100% legal and you won't lose much.
Nov 05, 2012 | Coby Tablets & eReaders
How do i unistal appslib and reinstall
Appslib is no longer supported for Coby tablets, we now use GetJar. You can download from the browser of your tablet by going to:
http://www.cobyusa.com/getjar-apk
Once you go there, it will start a download on your tablet automatically. Once finished, tap it to install.
You cannot get rid of the AppsLib as it is built into the tablet operating system unless you root your tablet.
Dec 26, 2011 | Coby Kyros MID80244G Tablet
My apps libaray on my coby kyros mid7015 isnt working!!! everytime i try to go into the apps libaray it keeps saying that theres been an unexpected problem and that it has to "force close" why is...
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Cannot access Appslib app library on Kyros tablet, using wifi. Will not allow downloads and constantly discontented.
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
Dec 29, 2010 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
44 people viewed this question
Top Coby Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
Lawrence Oravetz
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
