Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
I belive that, PC can detect the Printer and the only problem, the drivers are unabled to route the print queue and that creates a problem.
If your OS is XP/Vista/2000, try the below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall. ((IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : Datamax M 4200)).
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
