SDHC memory card worked for a long time and now the camera says "this card can not be used". I have replaced the card with a new one, and the message is still the same. Please advise.
The camera is rejecting the memory card. See above description.
Re: SDHC memory card worked for a long time and now the...
Have you replaced the battery, sometimes it is a low voltage and does odd thiings? have you went into the menu go to settings an reformat the card. remove the batter and start over. sometimes if you can get a q tip or simular item on to the contacts you can use alcohol or tuner cleaner to clean the contacts. make sure it is dry before you turn camera on. if not you will need to take it to a service place. and may dont evenn try to repair them any more. its a throw away age. i fixed me my self. but i hope you can too
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Is it an SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB All other V-Series Cameras: SD memory cards up to 2 GB EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok. I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
