Replaced bad relay (Ice O Matic 9101084-01 Relay, 2 pole, 120 V) Adjusted delay timer Leveled the machine out
SOURCE: I HAVE A ICE O MATIC 0250HA4 which start making
the thickness sensor is too close to the where the ice is being made. you will need to either bend it out a bit or use the adjustment screw. the latter is more preferred.
SOURCE: ICEU220HA1 ice machine is half full of water -
You have a restriction in the drain line beyond the ice machine and the water is backing up into the unit. You can try some Drain-o or snake the drain.
SOURCE: ICE-O-MATIC ICEU220HA2 bridge too thick. Is the
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU220 with R-404A should cut in at 45psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Hi AJ Davis, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? The above doesn't look like a question. If it didn't solve the problem (and I have to assume it didn't) What is the problem now? is it still making blocks at the bottom of the grid? Is the ice at the top of the grid normal, thicker, or thinner than normal?
