Remove the toner waste bottle, clean out the whole box and duct work. While there clean out the whole unit. Restart the unit by unplugging it and hopefully it will be ok. Sometimes the power board goes but hope for the best.
Testimonial: "thank you, it worked out very good, unfortunately now i have the problem that it prints a black layer on the hole surface..any new suggestions ?"
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
The wate motor transfers (you guess it) waste toner to the waste toner
bottle. If the bottle fills up, the motor cannot transfer more waste to
it. This is rare, for the printer should ask for a new waste toner
bottle when the previous one fills. However,it happens frequently when
users try to empty and clean the bottle instead of replacing it.
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
This is a very unusual error. 929 refers to the waste toner motor not running properly. Remove the waste toner bottle and put a hoover to the outlet to the bottle in case the toner is hard and blocking the exit of toner into the bottle.
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
