Tablets & eReaders Logo
L
Lauren Dodd Posted on Jan 31, 2015
My Nextbook 8.1 Tablet either won't connect to available wifi networks that it did connect to only a few days ago OR it will connect to wifi internet but I still can't browse or use an
I've tried disconnecting and reconnecting and turning the tablet off and then on again. I've tried 2 different wifi connections (one being my mobile hotspot) and neither is working. It was working fine about 3 days ago and then all of a sudden, it stopped. I've had it since the 20th of January 2015.
Jose Ortiz
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 7 Answers
  • Posted on Jan 31, 2015
Jose Ortiz
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
7
Questions
5
Helped
2315
Points
20
Try connecting it with pressing the wps on your router and on your tablet select the wps
Don't know how to set up next book 8 tablet for internet
Go to setting> wifi turn wifi on. It should scan for available wifi signals. Pick yours, enter the password for your wifi.
How do I find out which product I have? It is a Nextbook with Windows 8.1
Nextbook 8 Tablet - Welcome to Nextbookusa.com
nextbookusa.com/productdetail.php?product_id=22
The Nextbook 8 comes with the Windows 8.1 operating system, 16GB of internal memory that can ... With WiFi and Bluetooth support built-in, the Nextbook 8 can connect with everything you need at home and on-the-go. ... Product Registration.
Nextbook 10.1 - Welcome to Nextbookusa.com
www.nextbookusa.com/productdetail.php?product_id=21
The Nextbook 10.1 comes with Windows 8.1, an IntelĀ® ATOMā„¢ quad-core ... Playing video games is better, too, with the 3-axis G-sensor support, which lets you immerse yourself and move the way you need to. On-the- ... Product Registration.
Nextbook Flexx 10.1" 2-in-1 Tablet 2/32GB Quad Core ...
How do I connect a HP7520 photosmart printer to my Nextbook tablet so I can print from it
1. Connect your printer to your home WiFi network.
2. Connect your tablet to your home WiFi network.
3. On your tablet, go to the Play Store and download and install the HP ePrint mobile app (Android version).
When you want to print a document from the Netbook, just open the app and follow the instructions.
http://www8.hp.com/us/en/products/printers/product-detail.html?oid=5283357#!tab=features
https://play.google.com/store/apps/details?id=com.hp.android.print
I am trying to connect my tablet to my home network, but it isn't connecting... how do I fix this?
If your WiFi is ON then the station ID should be showing when you look for a wifi signal with your tablet.
You should configure the Access Point with a new password and then attempt to log in with that new password.
You may need to uninstall the driver for the wifi on your tablet and re-install it using a new driver.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
How do I connect my Nexbook 8 to the internet on my laptop
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
2answers
Why will my nextbook 8 not connect with my home wifi
  • Can you see your router from the tablet? If not, check to make sure that WIFI is enabled in the Android settings.
  • Does your WIFI have a password? If so, you need to enter the password in the Android WIFI settings entry for your router.
Nextbook 8 cant get wifi to work now - worked before??
Hi there
You have checked that you are joined to the network via the router?
The laptop most certainly is.
Try disconnecting the router and turning the Nextbook off for a few seconds, connect the router on again and open Nextbook.
Join the network again and put the password in.
This way of connecting has worked for me. Hope it will for you.
4helpful
My nextbook 8se keep freezing up. I've only had it for a couple of days and I'm already getting ready to take it back! Any suggestions to why its doing this?
I don't know if this is available on that model. Give it a try. Press and hold the power button until you get the menu with the option to power it off. Press and hold your finger on the option to power it off for a few seconds. Hopefully you get an option to reboot the tablet into safe mode. This mode will disable all third party apps on the tablet. See if it freezes up. If it doesn't one of the apps is causing it to hang. This will at least tell you if the tablet itself is bad or if it is a problem with an app.
2answers
I have the Archos 101 internet tablet but have been having trouble connecting to the wifi recently, I try to connect to a secure connection (I have the password and it is correct as I did connect a few...
Hi there. I noticed that sometimes Android devices seem to have trouble connecting to certain access points or.they seem to stop connecting alltoghether to certain routers. Sometimes this method can help: Select the network you are trying to connect to and select "forget this network". Reboot the tablet and try to reconnect again. Sometimes this doesn't work on the first try. If that doesn't work I have heard of other fixes but they require "rooting" the tablet which could be potentiall dangerous. Another thing you can try if that doesn't work is change the security to a different encryption type. Your password will either be WEP or WPA. Whatever it is try to change it to the other. I cannot give you detailed instructions on this because I don't know your router model or its current settings. Hopefully this helps and leave a comment if you have further questions. Good luck!
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
