My Frigidaire stacked washer/dryer has a squeak during the washer spin cycles. The entire machine has a bit of a shake that causes the frame to squeak. The machine is in balance and not sure what migh
Check level, Can hold the frame still and the squeak goes away.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Hello. Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator. 1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded. 2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle. 3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes. 4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle. Thanks.
Make sure the spin is working. If its not working you wouldn't know it since it spins during the middle and end of cycle. If not check lid switch Thank you for using fixya Leo Ponder Please rate me if this helped.
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
no you do not need to put them on rollers. yes it would make it easier to service them but rollers would not be stable enough to keep the washr from shaking in spin cycle.
