Question about Samsung Galaxy Tab on 3 Mobile Tablet PC
Have galaxy tab3. less than 6 months old. rarely used. battery went down. this is 3rd time to charge. it will not come back on. don't know if it is charging or not.
Tablet will not power up. battery runs down from no use. it is less than 6 months old. last time we had to trouble shoot to get back on it after a charge this time it is not charging or is just not coming on. any suggestions will be appreciated.
  • JP Mi
    JP Mi May 02, 2015
    Finally fixed mine. I had being trying all of the posted fixes for this to no avail. But on Chris's website link there was a comment to unplug the battery, plug in the charger and while it is plugged in, reconnect the battery. After 3 months of black screen we are charging. Finally. Be careful how you hold the unit while the back off it is still a circuit board and susceptible to static...so to chris, the other guy and everyone who got us this far, thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 2,003 Answers
Is the charger working? Have you tried plugging it into a PC?
Posted on Jan 31, 2015
  • Samsung Master
  • 3,015 Answers
Try this
Plug in the charger.
Hold down the "power on button" and the volume up button at the same time for approx 10 seconds
Give it a couple of tries to wake it up.
Posted on Jul 05, 2016
    Champion:
  • 221 Answers
Tablets generally do not have a CMOS battery and as such they use the main battery to power the device and keep CMOS settings. Most Android device do not like to be stored with a battery of lower than 14% or 7% depending on device. One this has be reached or passed it can be difficult to restart a device. From past experience Samsung Tab 3 and lower are one of worst culprits. The way to fix this issue from past experience is to remove rear cover and unplug battery for and hour or so. Then reconnect the battery and plug in the original or equivalent 2 amp USB charger. The tablet will think you have installed a new battery. You will loose all date, time, geographic location settings. You should NOT loose any apps or account settings. This has an 80-90% success rate. Try not to let the battery drop below 7% and if storing or not using for a while, I Suggest fully charging it before putting in storage.
Posted on Feb 05, 2015
    Renaissance:
  • Samsung Master
  • 884 Answers
Hi
A general tip is that batteries much prefer a charge - discharge cycle, rather than just being left. They last much longer that way.
However that's by the by. Firstly, will the Tab 3 operate whilst plugged into the charger? If it does then this is a clear indication that the battery or the charger is at fault and a replacement may cure your problem.
Secondly, is the charger supplying a voltage to charge the battery, if it isn't then it is faulty. If it is then either the battery, or the connections within the Tab 3 are faulty.
However, these are all relatively hypothetical, as after only 6 months it will still be under warranty and I would suggest that you take the Tab back to the vendor and request a replacement, as it cannot be regarded as of "Merchantable Quality". Alternatively contact Samsung, also under warranty.
Hope this is helpful, if so would you please register that with Fixya
Cheers
6ya staff
SOURCE:
Tip
Samsung Galaxy tab3: Display time and date wrong.. system time and date ok.
When clocks went forward for British Summertime I noticed that although tablet system time was correct the weather app display on home screen stayed 1 hour behind.
The fix it to enable 'location' (GPS) then click sync circle..then all was fine..after that could turn of location and stil kept correct time.
on Mar 31, 2016 | Tablets & eReaders
My Galaxy Tab 3 7.0 will not turn on. Is there a way to reset it?
Press the power button and the "up" volume to initiate a soft reset. If it turns on and you get access to your operating system then enter the setting a do a hard reset to re-install to the factory settings. If any of these don't work then it might be time to use the warranty and have it fixed.
Aug 17, 2014 | Tablets & eReaders
What/where is ssid number on galaxy tab3?
The SSID is the Name given to the Wireless-Connection you want to join. Browse your Router-Configuration for these information.
Jul 20, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
Why does my Galaxy Tab 3 does not take a charge?
sounds like the battery is faulty, speak to the supplier you got it from it needs a replacment battery check your warranty
Nov 13, 2017 | Tablets & eReaders
Tablet is less than a month old and has significant battery charge, and in the middle of playing an everyday app game the tablet went into a white noise picture. I shut it off by holding the power button...
hold down power and volume up and down at the same time for 10 seconds and then release. should reboot. if not then there is something wrong with the board or a software glitch.
Feb 13, 2018 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab on 3 Mobile Tablet PC Logo
151 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
