Question about Sanyo Televison & Video
I have a Sanyo 2008 DP32648 when you push the power button the green light comes on but nothing else works
    Sergeant:
  • 290 Answers
First thing try cleaning it. I got a HP 1020 laser jet (plus a second ink cartridge) for free two years ago from a friend who said it was not working anymore. I got out the Q-tips and glass of water plus some 99% denatured alcohol for some metal parts (alcohol melts rubber) and I've printed out thousands of pages since on that same printer and it's on its third (purchased number 3) ink cartridge. Also, what happen prior to the failure. For instance, I aborted a printout which probably corrupted the buffer and power rest did not clear it.
Posted on Feb 01, 2015
6ya staff
SOURCE:
Anonymous
SOURCE: Help
power adapter is failing, get a different one and see.
Posted on Oct 31, 2007
Anonymous
  • 3 Answers
SOURCE: The screen is black. When
The company states they will repalce it but not with this same tv becaise they no longer have it. Yeah I guess so, it's a total piece of ****. The company states they will send a different one and it will probably be better than the one before. ********!! Call them and get an RMA # so you can pay the shipping and get another tv that will work a few months more until the warranty lapses and you;re stuck with it.
Posted on Jan 03, 2009
Anonymous
  • 1077 Answers
SOURCE: Power will not come on. When you push the power
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you. Sorry I didn't get to you sooner.
Posted on Jul 13, 2009
Chi Chu
  • 8457 Answers
SOURCE: Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Posted on Mar 26, 2010
Barry Compton
  • 125 Answers
SOURCE: 32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
Posted on Apr 28, 2010
Green light comes on but nothing else. Could it be a fuse or inverter board?
Do you have sound? If you look closely at the screen with a flashlight can you see images?
May 07, 2016 | Sanyo DP32648 32 in. LCD TV
SANYO FLAT SCREEN TV DP32648
If you start it and it comes up and after a short time it shut off then take a canister cold spray and if it comes up again then you are on the right way that can may be tell you what the component is OR (soldering sometimes)witch heat driven component the priority has.
or manipulate with a not non-conductive object the electric prints. or it look like a soldering or a thermical defect.
Feb 13, 2016 | Sanyo Televison & Video
Sanyo DP32648 I have sound and backlight but no picture. Is this most likely the Main video board or could it still be the power supply? I tried sending signal from computer at all resolutions to no...
I should say, it's either the inverter cable needs to be re-seated/replaced or the LCD screen needs replacement.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Aug 21, 2011 | Sanyo DP32648 32 in. LCD TV
Will not come on it worked fine earlier.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 17, 2011 | Sanyo DP42849 42 in. HDTV
Pushed the on button, the green light comes on,
Green light comes on, what about other indicator lights? Is there activity like fans humming. Try to take out the battery and power up using the ac adapter only.
May 12, 2010 | Acer Aspire One PC Notebook
Sanyo DP42746.Can't get tv to come on. The green power LED is on.
unplug the power connector to the tv, wait two minutes then plug it back in and try to turn on the set... this worked for me.
Dec 20, 2009 | Sanyo DP42746 42 in. Plasma Television
Wont turn on
I have the same problem. When I push the green button nothing comes on - just the green LED keeps blinking.....could you manage to find the solution
Sep 28, 2008 | InFocus User guide, LP500 / 530 Projector...
Help
May 06, 2007 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
