Drive Medical Sunfire Power Based Wheel Chair Blue 1 ea Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sigh check is flashing? what is this? on a sunfire 95
oregoon
Level 2:
  • Expert 175 Answers
  • Posted on Jul 07, 2009
oregoon
Expert
Level 2:
Answers
175
Questions
0
Helped
107766
Points
363
I am not familiar with a Sunfire "95" powerchair. Drive makes a Sunfire General and Sunfire Power Plus, however, which have diagnostics for troubleshooting the flash code in the owners manual.
Here's a link to that site for the owners manual if you lost yours. https://drivemedical.com/catalog/omfiles/SPGT-3C-BL_Manual.pdf
Troubleshooting and flash codes are on page 26.
Will a 95 poniac grandam altinator interchange with a 2000 poniac sunfire
Go to e-bay and type in either or both of the alternators, and after searching a few of those offered for sale, you will see a list of all the different cars and models they fit. At accordingly.
Be blessed.
2helpful
2answers
Car runs but when put in gear stalls
if your car stalls or trys to lerch forward when stoping at a light or stop sigh, then your over drive is loked meaning you need to have your transmition serviced or the electrical to the lockup solinoide needs to be checked
3answers
Pontiac sunfire 2.2 1995 no spark from spark plugs
check for power coming from coil packs to wires, could be bad wires, coil packs, ignition module(under coilpacks). check all fuses as well
A diagram for 95 pontiac sunfire 2.2l with ac
can u hook up a 2200 1998 sunfire motor in a 1995 sunfire 2,2?
3answers
Check engine light for a 1995 pontiac sunfire
OBD 1.5 OBD 1.5 refers to a partial implementation of OBD-II which General Motors used on some vehicles in 1994 and 1995 (GM did not use the term OBD 1.5 in the documentation for these vehicles - they simply have an OBD and an OBD-II section in the service manual.)
For example, the 94-95 Corvettes have one post-catalyst oxygen sensor (although they have two catalytic converters), and have a subset of the OBD-II codes implemented. For a 1994 Corvette the implemented OBD-II codes are P0116-P0118, P0131-P0135, P0151-P0155, P0158, P0160-P0161, P0171-P0175, P0420, P1114-P1115, P1133, P1153 and P1158.[1]
This hybrid system was present on the GM H-body cars in 94-95, W-body cars (Buick Regal, Chevrolet Lumina ('95 only), Chevrolet Monte Carlo ('95 only), Pontiac Grand Prix, Oldsmobile Cutlass Supreme) in 94-95, L-body (Chevrolet Beretta/Corsica) in 94-95, Y-body (Chevrolet Corvette) in 94-95, on the F-body (Chevrolet Camaro and Pontiac Firebird) in 95 and on the J-Body (Chevrolet Cavalier and Pontiac Sunfire) and N-Body (Buick Skylark, Oldsmobile Achieva, Pontiac Grand Am) in 95.
Depending on the year and the vehicle, a car with the OBD 1.5 system may have either the older OBD-I connector, or the newer OBD-II connector, but they are electrically identical to each other.[citation needed]
The pinout for the ALDL connection on these cars is as follows:
180px-obd-connector-pinout.png magnify-clip.pngFemale OBD connector pinout 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 For ALDL connections, pin 9 is the data stream, pins 4 and 5 are ground and pin 16 is battery voltage.
Additional vehicle-specific diagnostic and control circuits are also available on this connector. For instance, on the Corvette there are interfaces for the Class 2 serial data stream from the PCM, the CCM diagnostic terminal, the radio data stream, the airbag system, the selective ride control system, the low tire pressure warning system and the passive keyless entry system.[2]
An OBD1.5 has also been used on Mitsubishi cars of '95 '97 vintage.
An OBD1.5 has been used in some 1995 Volkswagen VR6's (Juice Box's GTI)
2answers
Stalls after it runs awhile,
egr valve is open, have it checked.it might be the egr valve itself or the siolinoid
Top Drive Medical Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
