Hi,I have a samsung 32inch tv model le32s86bdx/xeu and when i went to turn it on it took a little while to come on but says no signal,iv tried it on a different ariel and still does the same thing any suggestions what it could b?
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
www.partsstore.com is a certified distributor for samsung just enter the make and model number of your set and it will bring up all the parts they carry. They usually have circuit boards for samsung
the problem is the power supply, check and replace regulator ic or even check the zener diode that trigger the regulator it maybe open or shorted......
