Linksys E4200 Maximum Performance Dual-Band Wireless N Router Logo
Posted on Feb 01, 2015
What is the address in Whitby for router parts
2answers
Postal code for Whitby Toys R US
Go to USPS and enter address for zip code.
2answers
This is a - Maximum router for wood work
Look up the manufacturer and model number on the Internet. Find replacement parts and order them on line.
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
2helpful
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
I have a vulcan wall heater with serial number 44674 made in 1981, needing to replace the fan as it's not blowing out hot air...Where can I find this part?
hello,
all Appliance part can be fine in various shop around you, our website www. appliancecanada. com is full of Electric heater Electric Cooktops · Gas Cooktops. Microwaves ... Sales centres are located in. Toronto and London, Canada. ... Scarborough, North York, Barrie, Vaughn, London, Woodbridge, Pickering, Whitby, Ottawa, Kingston, North York, Hamilton,e.t.c.
thank you and thanks for using fixya.
No internet connection. I bought this embarq 660 on ebay and am trying to use it with another dsl provider. I got the router part to work with laptops just can;t connect to internet. please help
You can't just connect up a new router to some ISP's (internet service provider) and expect it to work. My ISP requires the MAC address of the router before it can access the internet. Call your ISP and tell them what your doing. The MAC address is the physical hardware address of your router (there is no other one the same in the world). The MAC address is on a sticker on the router and consist of 12 numbers and letters.
Connection (or disconnection) difficulties
The time span for the assigned IP address are controlled by the router in the DHCP configuration, which can be set to your satisfaction, by accessing the router configuration page, by entering http://192.168.0.1 in the internet explorer address window. Be sure to use the IP Address assigned to the router.. Also you can release an IP of a computer by opening the MS/DOS command window by clicking Start/Run and typing in CMD and then enter at the courser ipconfig /release this will release the ip. then type ipconfig /renew this will reset the ip of the computer. If this helps please rate as a FixYa. Thanks BPCS
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
