Plug antenna cable directly into antenna input on tv. Place antenna where you believe you will get a signal (don't know where you live but you can look up site map for optimum direction). Go into tv menu set tv to air and auto scan air channels. Your set will receive and memorize available channels. In your sets menu you should have a strength meter. You can use this to tune in the strongest possible signal. You may have to go back and rescan the channels because if you improve the antennas position you might pick up more channels and they won't just come in automatically. Once you've scanned and received maximum number of channels there will be no need to rescan again. If you do you run the risk of losing some channels and only a rescan under optimum conditions with regards to antenna position and environmental conditions will gain those back. Keep in mind some fringe channels may come and go. Hope this helps.
