you will have to op[en up a paypal account type paypal create account into your internet search when you get to the paypal login page at the bottom you will see new to paypal sign up tab paypal to create an account paypal registration =password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress log onto your paypal account under profile you will see your credit/bank cards there you will see a list log in to your paypal account Add or Edit Email Add or Edit Bank Acc Addor Edir Credit Card Add or Edit Postal Adress over to the right you will see a contact us tab tell them of your problem/dilemma make a list of problems you have with regarding your account and see if they can help im sure they will help other than that you will need to contact paypal give them a free call 1800-073-266 6.00 to 22.00 AEST/AEDT to resolve this issue they might ask you some personal details you made when you first made your paypal account so i you can remember these have them ready hope this helps
This is now handled by Hydro-Gear. www.hydro-gear.com.
BDP stands for Bantam Duty Pump and the rest of the code calls out the configuration of your pump - shaft, rotation, size, etc.
What is the model number and brand of your pump? Your description is a classic statement when hydros (your pump and motor) are failing. You can try charge pressure adj to make it work better. Model number will tell me where to direct you.
I'm having the same problem, except mine is not hydrostatic. A 1996 craftman tractor 15.5 briggs 42 ' deck. About to start pulling out my hair!!! Just put on a new drive belt and still no movement.
Limit the pressure supplied to the inlet of the motor, plug the return port. Place the case drain line into a bucket, or install a case drain line if not equiped and comparte the flow to the manufacturers specs. I don't know what they are off hand, but shouldn't be more than 1 gpm I wouldn't think. Another quick test is if you can turn the bare shaft easily with no resistance when both fluid ports are open, the geroller set has quite a bit of wear. This quick test doesn't work in some applications such as wheel motors as they are sometimes ordered as "free running" motors. They are the same motor, but with a looser fitting geroller set.
Please visit http://hansonhydraulics.blogspot.com for more information.
try these guys:https://www.abgo.co.uk/
