SOURCE: Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
SOURCE: Hi my Hoover Nextra 6
the lights indicated a blockade, remove the front panel at the bottom to reveal a drain plug, the blockage is most likely at the back of the drain plug as the drain motor impeler sits directly behind the plug.
hi all, thanks for all answers, but i have now repaired fault, i thought that fault was with sensors at heater box, as it was just as cheap to replace complete unit than both sensors i did that, but to do this i had to remove front cover to get to connectors in behind the main front panel, the one that surrounds the door, there is a sensor in there, i found it had fell apart, all parts were inside front panel and were easy to clip back together, refit panel and now spot on, hope this helps others, message me if you need any help with strip down of panel.
thanks
jim
What sensor was faulty?
