Question about Dream Maker Spas Dream Maker Spa - Fantasy Sandstone with Cover
I have a DreamMaker Fantasy Spa. It recently started flashing "OH" (Overheat) on the topside control pad. When tested, the water temperature was 91 degrees. I unplugged the tub and let it set for 5
I cleaned the filter and tried resetting the tub several times. I've also purchased a pool thermometer to more accurately monitor the water temperature. The topside control is not locked or in economy/sleep modes- I checked that as well.
  • Dream Maker ... Master
  • 1,631 Answers
Very likely your Temperature sensor has failed.
Posted on Mar 10, 2015
    New Friend:
  • 79 Answers
How old is it maybe motor OH
Posted on Feb 02, 2015
  • 2 more comments
  • Justin Gardner
    Justin Gardner Feb 02, 2015
    minutes or so. Upon plugging it back in, it appeared to work as normal for a day. Once it heated back up, it continued to run past the set temp of 102, until it surpassed the safety limit of 108 and reverted to "OH" mode. Sometimes it will continue to run/heat beyond this point and sometimes it will not. Either way, the topside control is unresponsive once it starts to flash "OH".
  • Justin Gardner
    (For some reason, it cut off most of the original question.)
  • Justin Gardner
    It's 2 years old. Why would the motor make the water temperature fluctuate so dramatic/erratically?
  • Mike Tellegen Mar 11, 2015
    The motor will not create a readable error code on the topside control panel of OH. If the motor overheats it will turn off itself, and then the error code will be FLO, because it won't communicate with the circuit board logic. The board is still sending power to the motor, but it is off, therefore the flow switch will communicate to the board that the flow had stopped.
6ya staff
SOURCE:
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
How can we clear up our water? I 've boosted it 2 times. test strip says low. Still greenish.
Backwash your pool or clean your filter well. Then try putting in green algae algaecide and a clarifier. They are both fairly cheap. Then run your filter for several hours.
Jun 10, 2015 | Pool & Spa
Heater temp is 78 the water temp 68 how do I reset heater temp to match pool temp.
Sounds like a faulty temp sensor. Check it for debris, clean it good and see if that does it. If not try replacing it.
Jun 02, 2015 | Pool & Spa
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Index sand filter pump SF 20110 will not blow water into pool
I don't know how much time you are giving it, but sometimes when I start my pump, it'll take 20 minutes or so for it to start a full stream of water. Also, make sure the valves are turned to the unlock position on the incoming and outgoing hoses.
Jun 03, 2014 | INTEX Sand Filter Pump
Hello pool experts, I'm also an expert here at FixYa, (I'm an appliance technician by trade) and I have a question in regard to a pool I have (purchased the home in Phoenix with salt water pool...
Salt, Calcium and Cyanuric Acid are the only 'chemicals' which are persistent in your pool. Translation: you can't adjust them downward with another chemical. To reduce these 'chemicals', you must change the 'contaminated' water with new, 'uncontaminated' water. Do you know what the natural calcium level is in your 'fill water'? It is doubtful your fill water had cyanuric acid or salt. If you have high calcium levels in your fill water, (check your fill water with your pool tester)(BTW, I recommend a Taylor K-1005 or better for your pool testing needs. I dont care for the strips) you will have to import low calcium water. (Oh yes, there will be splash out and you will carry out water on your bathing suit - this will remove these three chemicals from the water. Evaporation does not affect these chemicals, however.
Where does the cyanuric acid come from? You put it in. Why? Because the chlorine you make is un protected. The UV will eat it almost as fast as you can make it. Of course, if this is an inside pool, you will not add it to the water. Chlorine in tablet or grandular form comes with cyanuric acid built in - it is called stabiliser.
Preferred calcuim level for a salt water pool is around 300 though the acceptible range tops out at 1000. In a high calcium condition, the water will start throwing the calcium onto the walls of anything it can, like your salt water power cells, walls of your pool, where ever it can stick. Cyanuric acid can be as much as 100 but 80 is better. Many salt systems like to operate around 3400 to 3600 ppm. Check with your manufaturer for the actual salt level.
I don't know if calcium can be deposited to the walls of your filter and plastic piping. If you have metal piping, you have several problems, first, the water eats the metal all by itself with no help. You have salt in the water and that just helps the water eat the pipe faster. When there is metal in the water, that metal has to be removed - it goes into the filters onto the walls of everything it can stick to. You can use a sequestering agent to help remove the metal ... but it is just a matter of time until the pipes will fail. Second part of the metal problem, the metal and the calcium will stick to the plates of your salt generator cell. This restricts the water flow, reduces the amount of chlorine that cam be generated and it is very tuff on the plates. You can scrape the stuff off the cells and you can acid wash the cells (25% muratic acid 75% water) but this is not good for the long life of your cells either. Follow the package directions for the sequestering agent. It works best when there is little chlorine present, BTW
You stated you have DE filters. These are probably the best type of filter to have as they remove the smallest particles. However, they also require higher maintenance and they are also metal. I had a hot tub with a DE filter. During periods of high use, I might get as little as 2 weeks use from a freshly cleaned filter. I changed that for a sand filter. I still exceed the state turn over rate by 50% (Turn over rate is the time to filter all the water in the pool - 4 hours for a hot tub - 8 hours for a pool - your pool is private and probably does not have to meet any commercial standard) and I back wash only when the pressure goes up 10 pounds from normal operating pressure. My hot tub sparkles and is no longer a high maintenance item. The leaves of a DE filter look pretty gross when they are clean, BTW. The DE of course is a mud like product when it is wet. It coats the leaves and as you force the water through, it traps everythiung down to 50 microns. When you wash it off it is really gross looking. BTW - some say DE is dangerous when it is dry in the same manner that asbestos is dangerous (there is no evidence to support this at this time) ... HOWEVER - DO NOT BREATH IT before or after its use.
Why exceed the trunover rate? For a cleaner pool with less hands on cleaning. The filters do the work. Of course, we pay a little more to the electric company. The turnover rate is minimum for sanitation purposes. It is fine to exceed the rate.
Your pumps may require close watching. A small fresh water leak is no big deal in a pool situation though I don't recommend ignoring any leak. In a salt water pool, your pumps are days from destruction from the littlest of leaks. The salt will eat the bearings and the windings and never show you a sign that it is doing its work. I lost two motors this year due to salt. There was no evidence of a leak in my case.
I dont understand what you are saying about the electrical charastics of your motor(s). They are 120 or 240 and if you have a choice, they should be 240 and you should run them all the time as in 24/7. Yes, it costs more but your pool will be cleaner and you will have fewer mechanical troubles.
My aim is 5 ppm Chlorine (10 for hot tub) - 7.2 pH - 100 Alkalinity - 300 ppm calcium - 80 cyanuric acid - 3500 ppm salt.
I hope you have found some valuable advice here ... if you have more questions, please add them to this question. It is my pleasure to help a fellow 'expert' here at FixYa.com. If I don't have the answer to your question, I can do what I do best, ask my "pro" friend.
milleraba
Oct 23, 2011 | Hayward EC-40 DE Pool Filter with pump
Pool filter return keeps stopping
If you have cleaned the fingers in acid you may have to replace the socks on the fingers.
Jul 21, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Dream Maker Spas Dream Maker Spa - Fantasy Sandstone with Cover Logo
817 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
wadingriver
wadingriver
Greg Bernett
Greg Bernett
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
