Vacuums Logo
E
Edward riches Posted on Feb 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dyson handheld works for 30 seconds the cuts out
  • Official Brand Answer 2,572 Answers
  • Posted on Feb 03, 2015
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1769425
Points
6009
Hi Edward, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson handheld. In order to help further, we would need some additional information about your particular machine, including which Dyson handheld model you own. It would also be beneficial for us to talk you through some quick diagnostic checks when you have your machine fully charged and easily to hand. We should then be able to help you determine which part is at fault.
At your earliest convenience, please give our experts a call - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
My Dyson DC35 stalls. I've thoughly clean it, so it's not a clog problem
1st make sure battery is fully charged.
Next, wash the filter, just follow the instructions in the manual.
If the filter is clogged the motor will try to run but then cut out to protect the motor from damage.
Runs for a few seconds, then stops
Hi Bente, it's Jack at Dyson.
DC16 was the first Dyson handheld vacuum, launched back in 2006. It would have come with a 2-year guarantee, but due to its age it's likely that this has expired now.
However, our experts would be happy to take you through some quick diagnostic checks when you have your machine to hand. This will help determine which part may be at fault - and therefore, what may need replacing to resolve the issue.
If you would like some advice, you can reach our team of experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
My Dyson DC31 runs for a few seconds then cuts out and won't work at all. It is fully charged. We bought it just over 2 years ago and it has worked perfectly until now. It is clean and has no apparent...
Hi Jean, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC31. If it cuts out in use when it's fully charged, we'd need to take you through some quick diagnostic checks when you have the machine at hand. This will help our experts determine what may be causing the issue.
Please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
http://www.dyson.com
2answers
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Dyson DC16 keeps cutting of after 2to3 seconds tried removing the small three leg resister and joint A and B together but still didn't work can any one help with this problem
Most likely it is your battery. the lith ion batteries die out over time. That is on of the symptoms of an old battery. Did you call Dyson? They have a 5 year warranty
1helpful
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
