My memory card was not in my camera when I took a dozen pictures and now I want to put them on my card so I can transfer them to my computer
SOURCE: How do I transfer pictures onto the memory card?
Take the memory card out and then hook up to your pc.
SOURCE: transfering problem
Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
SOURCE: transferring pictures
You might try putting the pix on a rewritable cd, and then copying them from that drive onto the smartcard drive with your card inserted. Or just try copying directly from your computer file to the smartcard drive with your card inserted, essentially using the computer's hardware to do the job instead of the camera's software.
SOURCE: How do you transfer internal memory pictures to
Put the memory stick inside the camera. Then open the photos which is save in your camera memory. Select them all & then you find a option Send to memory card or copy to memory card. Select that and press ok. Your photos transfer from camera memory to memory stick.
Thanks
Hi Brenda Thomson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model Panasonic Lumix camera? There should be a "Copy" command somewhere in the menu system.
