The solution is a factory reset....I know you have done this but did you follow these instructions?
1.Make sure the tablet is off and not in standby.
2.Hold down the 'Volume Up' and 'Power' buttons simultaneously until the two Android icons appear.
3.Use the volume buttons to select the white box on the right.
4.Once selected, press the power button.
5.Use the volume buttons to select 'wipe cache partition' and then press the power button.
6.Select 'Yes' and press the power button.
7.Use the volume buttons to select 'wipe data/factory reset' and then press the power button.
8.Select 'Yes' and press the power button.
9.The tablet will now reset.
SOURCE: my wi fi is not connected. How do I do that/
I picked 1 up for the first time and connected in 2 minutes.
In settings page where you add a wireless connection, you will need to know..
Security type, mine was wpa2 ( may be wpa/wpa2/wep)
SSID, your network name that is transmitted, mine was default
password, whatever the wireless password you chose with wpa, if you have wep, it gives you a pass key, you will need to log onto your router to get this
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: hi i have a pandigital novel book tablet
Please go to the Pandigital website and update the firmware, I will attach a link below.
Thanks for using FixYa
http://www.pandigital.net/Downloads
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
