P0138 code
P0138 - O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor2)
The Heated Oxygen Sensor (2) located rear of catalytic converter produces an output signal relative to oxygen storage capacity of catalytic converter. Ho2S 2 signal is less active than signal produced by front oxygen sensor. This code sets when HO2 Sensor voltage is greater than 999 mV for more than 2 minutes (time depends on model. Could be as high as 4 minutes)
Symptoms: There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
Causes: A code P0138 may mean that one or more of the following has happened:
* Faulty O2 sensor
* Short to battery voltage in O2 sensor signal circuit
* High fuel pressure (not as likely)
Possible Solutions: Here are some potential solutions:
* Replace O2 sensor
* Repair short to battery voltage in o2 sensor signal circuit
Hope helps (remember to rate and comment this).
Hi Brandon Baird, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Vehicle?
