Televison & Video Logo
l
larry lucas Posted on Feb 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg led tv backlight
I have an lg 47nl5200-ub led tv. the screen is black and it blinks on power up and power down. I can see picture with a flashlight so the backlight isn't coming on. I replaced the power supply board with no success. the sound works and you can use the menu screens if you use a flashlight.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Feb 05, 2015
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005055
Points
237762
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2answers
I have an LG 50LF6000-UB that the picture is out. You can see it slightly in a dark room. Is this the LED backlights or the board that powers it?
The LED and the board are no longer working for your TV and are going bad too. You should buy another TV than to try and repair the TV with the screen that is broken.
LG tv has no picture but has sound
You have bad LED backlight strips, VERY common failure, it amazes me how many people change the power board with no backlights and in most cases it's not the power supply that's bad
1helpful
No picture on my LG TV. Issue is either the LEDs or the LED driver on the Power Supply. LED+ sections on the Power Supply [62810801] give 79.3 volts. Is this a normal or a below power reading?
That is the right amount of voltage the issue is when one or more of the individual LED lights fail, the current changes and the power supply senses it and shuts down.
LG 42LN5300-UB TV HAS NO PICTURE AND NO BACKLIGHT
If you power on your TV but you do not see the menu options, or any video display - just a black, blank screen, and possibly no audio as well; try the recommended steps below to resolve the issue. Check if the status LED, in front of your TV is ON. ... To confirm, point the TCL remote towards the TV and press any button.
2answers
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2helpful
2answers
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
