You need to check battery to see if the battery has correct voltage. Their should be on the battery the number for voltage of battery if battery is not at suggested voltage then check for tablet with voltage meter to see if the tablet is charging at correct voltage. If battery is at correct voltage then something is wrong with tablet. If battery is not at correct voltage then probably battery is bad. Let me know for further assistance
You have a contact issue with your battery. ..even plugging it in you must have a good connection with the battery. I would try this take a piece of cardboard or paper and fold and wedge it in between the battery and the outer edge of the battery recess not where the gold colored terminals are located. Sometimes the battery don't make proper contact and this will ensure that it does. After doing this plug it in and let it charge for a while. When the icon for the charging battery gets to about the middle of the battery then hold down the on button until the icon disappears let go of the button and see if it works ok
Swipe down from the top. A band of icons appears. Look for the rectangle (top left I think) This is the Screen Lock Icon. Tap it to turn screen Lock OFF. (Or on the EFun it may be a Wheel icon for screen lock.)
