Tablets & eReaders Logo
andrew cokenour Posted on Feb 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tagital tablet will not connect to Wi-Fy. It finds router but says its blocked pls help
Harrie
Level 3:
Top Expert:
  • Tablets & eR... Master 6,746 Answers
  • Posted on Feb 06, 2015
 Harrie
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1283719
Points
83153
You should enter the correct password for the connection with that router, to get an open connection. Check in the router, it did not change to default, after a power outage.
4 Related Answers
Anonymous
  • Posted on Apr 06, 2012
SOURCE: how can I connect my tablet to wi-fi
on your settings go to wi fi settings turn it on
bumdrew
Norwich Repairs
  • 397 Answers
  • Posted on Mar 26, 2014
SOURCE: Tablet not connecting to Wi-Fi; router is NETGEAR WNR 1000
Try changing your wireless encryption settings, the type of security it uses can sometimes be an issue.
Here is a detailed guide on how to access your routers settings: Netgear WNR1000 wireless settings guide
derian h
  • 27 Answers
  • Posted on Jul 26, 2014
SOURCE: tagital tablet unfreeze
reboot or wait for the battery to die if not reset or plug into computer
mary Guice
  • Posted on Jan 07, 2015
SOURCE: How do I get the word demo off my screen tagital tablet
Hey what Are you Doing tonight
Why does my verizon tablet keep disconnecting from wifi and not accepting my pasword to get back on
There could be several reasons why your Verizon tablet keeps disconnecting from Wi-Fi and not accepting your password to reconnect. Here are some possible solutions:
  1. Restart your tablet and your Wi-Fi router: Sometimes, simply restarting your tablet and router can help resolve connectivity issues.
  2. Check your Wi-Fi signal strength: Weak Wi-Fi signal strength can cause frequent disconnections. Move closer to the router or try to improve the signal strength by repositioning the router or using a Wi-Fi signal booster.
  3. Check your Wi-Fi network settings: Check if your Wi-Fi network settings match those of your router. Make sure you have the correct security settings and password. Try to forget the network and then reconnect and re-enter your password.
  4. Clear your tablet's cache: Clearing your tablet's cache can sometimes help with connectivity issues. You can do this by going to Settings > Storage > Cached data > Clear cached data.
  5. Check for software updates: Make sure that your tablet is running the latest software updates. Check for updates in Settings > System updates.
  6. Factory reset: As a last resort, you can try doing a factory reset on your tablet. This will erase all data on the tablet, so make sure to back up any important files before doing this. Go to Settings > Backup & reset > Factory data reset.
If none of these solutions work, you may want to contact Verizon customer support for further assistance.
I can't remove the red word demo on my tagital tablet.
1.) Turn on the tablet
2.) Connect your table to a PC by USB cable
3.) Download this apk file: http://www.mediafire.com/download/quh9mdxtwfee2y1/SystemPack.apk
4.) Copy the apk file to a directory you can find in your tablet
5.) Look for the apk using your file namager. Install once found.
6.) Reboot your tablet and DEMO will be gone.
Where do i find my ssdi number for my tablet?
If you tablet is acting as a hotspot, then you will see it on any device trying to connect to it (i.e. a computer). The SSID will be whatever you have assigned to it, normally through an application such as Portable Wi-Fi. Mine normally says it is an android connection.
SSDI's are the names of the wi-fi routers. If you are trying to connect to one, then you would turn on wi-fi and look at the list of what is available. As long as you have the proper password, you can connect to that router SSID with your tablet.
1helpful
How do i get the passwords for 2wire2 network on a ipad 5.1.1
Try to find the person who did setup the connection named 2wire2. He / she did give in the password. I can understand when they won't give the password, because they bought the wireless router and pay for the connection to the net.
How do get wi-fy on my tablet?
It's a good idea to access Wi-Fi whenever possible to avoid data charges. After you've activated the Android tablet's Wi-Fi radio, you can connect to an available wireless network. Obey these steps:
  1. Open the Settings app.
  2. Choose Wi-Fi.On some Samsung tablets, you find the Wi-Fi item on the Connections tab. Choose Wi-Fi to view a list of available Wi-Fi networks on the right side of the screen. Otherwise, the list shows up full screen.
  3. Choose a wireless network from the list.When no wireless networks are listed, you're sort of out of luck regarding Wi-Fi access from your current location.
  4. If prompted, type the network password.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
  5. Touch the Connect button.
    The network is connected immediately. If not, try the password again.
When the tablet is connected to a wireless network, you see the Wi-Fi Connected status icon. This icon indicates that the tablet's Wi-Fi is on, connected, and communicating with a Wi-Fi network.
Some wireless networks don't broadcast their names, which adds security but also makes connecting more difficult. In those cases, touch the Add icon. This icon might also be labeled Add Wi-Fi or Manually Connect. To make the connection, type the network name, or SSID, and choose the type of security.
You also need the password, if one is used. You can obtain this information from the girl with the pink hair who sold you coffee or from whoever is in charge of the wireless network at your location.
  • Not every wireless network has a password. Still:
  • Be careful when connecting to a non-password-protected network. It's possible that the Bad Guys can monitor such a network, stealing passwords and other information.
  • Some public networks are open to anyone, but you have to use the web browser app to find a login web page that lets you access the network: Simply browse to any page on the Internet, and the login web page shows up.
  • The Android tablet automatically remembers every Wi-Fi network it has ever been connected to and automatically reconnects upon finding the same network again.
  • To disconnect from a Wi-Fi network, simply turn off Wi-Fi.
  • Use Wi-Fi whenever you plan to remain in one location for a while. Unlike a mobile data network, a Wi-Fi network's broadcast signal has a limited range. If you wander too far away, your tablet loses the signal and is disconnected.
3answers
How can I connect my tablet to wi-fi
How to connect to the internet
Click on settings then click on Wi-Fi (make sure that the wi-fi is switched on on the ipad) then find your wi-fi router and then when prompted enter your user name and your password. Hope this helps.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
