Because this is am older model, year 1987, I am having trouble finding a manual. I was told a lot of this material was lost when subzero took over the company. The contracter I work with is insistent I have the manual so he could review if there is a REQUIRED hood to be installed. If there are no requirements with this model I can move forward.
SOURCE: STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
SOURCE: what cookware to use on this cooktop
flat bottom cookware no rings on the bottom and no glass cookware
SOURCE: Wolf Gourmet Range oven lighting delay
UPDATE to Solution #1: I just went to the Wolf Appliance website and found that the recall is still active, at least for the 48" models. Here's the URL: http://www.wolfappliance.com/recall.aspx There are instructions, affected models and serial numbers, etc. You can also call the "Rework Hotline" at 866-643-6408 or send an email to [email protected]
SOURCE: what size rangehood is required
Hello, here is the best you can get at the moment without further information about your unit,installation location, etc..
go here:http://www.engineeringtoolbox.com/exhaust-hoods-d_1036.html
there are formulas for calculation hood cfm, and a calculator to input your dimensions that should get you close.
With that said, I would advise that if is that critical, call or contact someone in your area that does this all the time, HVAC companies/installers should be able to do this.
Hope this helped, and thank you.
SOURCE: KENMORE ELECTRIC RANGE MODEL NUMBER 790.9621340C
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Manuals available here:
http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=FGF316DSD+FRIGIDAIRE
