Took the tablet to a Samsung centre today they did a factory reset and it worked for a while until we put photos and music back on the tablet.
SOURCE: Samsung tablet isn't connecting to
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
SOURCE: My samsung Tablet is 10 wks old, a month after I
You should return the device. It sounds like a problem with the hardware or the software. A good many rooted versions of android exp. these same problems also.
Testimonial: "wow that was quick thanks."
You might have something going on in your settings. I remember the first time I tried to connect to a network. It was a nightmare. I was pulling my hair out! You only have one device to connect. I had three devices and none of them would connect until I went in and changed my settings. I hope this was helpful. Good luck.
SOURCE: Can I reset factory settings on Samsung Galaxy tablet
This hard reset can be done even if the device won't seem to power on.
SOURCE: How do I transfer photos from my laptop to my sm-P900 samsung tablet
Connect Samsung to laptop via USB cable. Laptop should mount the Samsung as one of your hard drives. You can then drag and drop files back and forth between the two.
