Dryers Logo
M
Marva Christian Posted on Feb 09, 2015
I need to install a conversion kit on my brand new GE gas dryer model gfds140gdww. I have to get it open to find the place to install the kit and there is no obvious screws etc. to open it. I am getti
We have searched all around but cannot find any screws that would take off any part of the exterior. We need to know how to get inside this dryer. Where are the screws located and where do we find the section to install the kit.
My GE gas dryer will not heat up model GFDS140GDOWW
See if any troubleshooting steps apply in page 21 of the free online manual below. Verify electric circuit breaker in your home is not tripped off.
https://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90497-3.pdf
May want to contact vendor GE for support.
https://www.geappliances.com/appliance/GE-7-0-cu-ft-capacity-gas-dryer-with-steam-GFDS140GDWW
Jul 08, 2020 • GE Dryers
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 • Dryers
How do I get inside a GE GFDN110glww so i can install the LP gas conversion kit?
Hello MacMarkus i need the same can you help me please!! this is my email, [email protected]
Can you covert convection ovens from propane
Determine the make and model of your dryer. You want to make sure you get the correct conversion kit for your dryer. Get one that is specifically for your dryer, not a universal kit.
Buy a conversion kit for your dryer. You will probably find one at a local hardware storemag-glass_10x10.gif .You can also find them online. It is probably advantageous to buy it locally because the dealer has experience installing these and can be a great asset. The kit will probably come in an envelope and will be marked something to the effect of “Conversion Kit Nat. Gas to L.P. Gas for XXXX series dryers”.
1)Shut off the gas supply to the dryer and make sure the power cord is unplugged.
2)Access the gas controls assembly in the dryer. This will be different for different brands of dryers. The instructions with the conversion kit should tell you exactly how to do this for your dryer.
3)Turn on the gas supply and check for leaks using a liquid soap solution and / or a leak tester.
4)Activate the dryer gas valve. Check to make sure the manifold pressure is correct and if not, adjust the regulator setting. Again, check for leaks.
5)Adjust the main burner flame as directed in the instructions with your gas conversion kit.
1helpful
How do i get to gas valve to install lp gas conversion kit on a ge dryer model drsr495gg7ww
call your lp provider as they often will send out a tech to do this conversion for free. after all you will be buying the gas from them.
Aug 17, 2009 • Dryers
1helpful
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
3helpful
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 • Dryers
COnverting it to propane
You need to change the orifice on the end of the gas valve and flip the cap on the regulator to the LP side. Model number would help.....?
Natural gas maytag dryer
You'll need a conversion kit for your model. Get your model number (inside door) and contact a parts place, local or online. It usually consists of an orifice & possibly a pressure regulator.
Jan 09, 2008 • Dryers
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
