Electrical Supplies Logo
kerim Posted on Feb 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Perkins 4008 over speed problem when we change the wood ward controler
Starlight Power
Level 2:
Sergeant:
  • Electrical S... Expert 117 Answers
  • Posted on Dec 06, 2019
Starlight Power
Level 2:
Sergeant:
Answers
117
Questions
0
Helped
96351
Points
657
1. Fault phenomenon of diesel generator overspeed
Under normal operation, the engine speed suddenly rises, so that the engine speeds up beyond the rated speed and loses control, and emits a huge roar, the exhaust pipe emits a lot of black smoke or blue smoke.
2. Cause of failure
The fundamental cause of diesel engine overspeed is that diesel engine loses or changes its speed regulation characteristics. Faults of fuel injection pump and governor, such as stagnation or looseness of relevant components, will cause excessive oil supply and loss of normal speed regulation characteristics, while the combustion chamber entering additional diesel or oil will change the speed regulation characteristics of diesel engine.
1) Faults of injection pump and speed regulator
2) Additional fuel enters the combustion chamber
3. Solution to overspeed fault of diesel generator set
https://www.dieselgeneratortech.com/diesel-generators/The-cause-of-overspeed-in-a-diesel-generator.html
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 573 Answers
  • Posted on Mar 01, 2015
Renee F
Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248145
Points
680
Check the mag pickup sensor on the flywheel for dirt chips of metal.
2answers
How to remove starter from a 4 cylinder perkins engine
Search Results
    [PDF]Perkins 4-154 Shop Manual
    www.kp44.org/ftp/Perkins_4-154_Shop_Manual.pdf
    88 Perkins. Engines workshop manual. 4.154. PRINTED lN U.S.A. .... removal, dismantling, assembly or refitting of a part is straightforward ... The ENGINE NUMBER is located on the cylinder ... starter motor, air cleaner, but without clutch. lb kg.
    Reliability built into starter motors - Perkins Engines
    www.perkins.com/en_GB/.../starter-motors.html
    Perkins EnginesYou can rest assured that your genuine replacement starter motor will work ... 4 Cylinder · 6 Cylinder ... You can learn more about these cookies and general information about how to change your cookie settings by visiting our Privacy and Cookies page. ... This need for dependability is why we test each of our starter motors.
Bose solo stopped wiring. Changed optical cable no change
  1. hellllo......you need bose tec support 800-367-4008..........TX..........g.scott
2answers
How to download ecm software for perkins engine DSE 404D.22 made in UK
my name is christian i m a gen technican based in abuja . pls i need some soft ware to repaire gen
When I have a large piece of wood on the lathe say 25 lbs or so and when I turn it fairly fast above 600 rpm after it is nicely balanced if I now turn down the speed control the machine shuts down. I
this is a safety feature built in.. if you turn down the speed to fast to keep the motor from sticking and burning out, it cuts off.. if you do it slowly you will be fine unless you go too slow in which case it will happen again.
Bought a house, it has a montgomery ward heater.... got questions!
Re: And what is that odd circular flap partway up the chimney?
It's called a "Flue".
2answers
I have a Montgomery Ward Wood Burning Heater (model # 81-SJW-56212). Where can I go to get replacement parts?
Your wood burning heater has been out of manufacture for some years now and OEM parts are almost non-extent. However, if it's a damper door or something like that, I would suggest taking the part(s) with you and visiting a wood stove dealer in your area. Some parts are fairly generic and can be interchanged. I believe that Warm Morning (Martin Industries, who is no longer in business) manufactured the stoves for Montgomery Ward. If you can find some Warm Morning parts, you may be in business.
Good luck in your search.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
