Question about PEAK 450 Plus Portable Power System
Looking for the reset the low charge alert button.
  • Anonymous Feb 10, 2015
    I less than 5 minute of my email to the company, got this email!
    "A replacement LCA pin will be sent out to you as a courtesy and should arrive within 5 business days."
    that's what I call a great support and service :)
    thank you peakauto.com !!!!
  • PEAK Master
  • 1,645 Answers
There is not such a setting , Low power will show amber colour .
Posted on Feb 19, 2015
6ya staff
SOURCE:
Wont turn on after reset
The iPod Touch has a battery capable of up to 40 hours of audio playback, but depending on how you use your iPod, the battery capacity can vary widely. If you attempt to turn your iPod on and get no result, the battery could be fully drained, which you can easily resolve by connecting it to your computer to recharge it. If this doesn't work, resetting or restoring your iPod may get it working once again.
Charge Connect your iPod Touch to your computer using the USB cable that came with it and charge it for at least 10 minutes before attempting to use it again. If the battery is fully drained, the screen may remain blank for a few minutes after plugging it in, and then a low battery image will appear, indicating that you shouldn't unplug it for at least 10 minutes. Never plug your iPod into your keyboard, but rather into the computer itself. Also make sure your computer is on and not in sleep mode while your iPod is charging, or the battery may drain rather than charge. Reset b> If recharging your iPod doesn't resolve the issue, reset it while it remains connected to your computer. Push the "Sleep/Wake" button and the "Home" button simultaneously until the battery symbol or the Apple logo appears. This takes about 10 seconds. Continue to charge your iPod if the low battery image appears after the reset. Restore b> If your iPod Touch still isn't responding, restore it in recovery mode. First, place your iPod in recovery mode by disconnecting it from the USB cable, and then press and hold the "Home" and "Sleep/Wake" buttons simultaneously until the iPod turns off. Push the "Home" button once again, and continue to hold it while you re-connect your iPod to your computer using the USB cable. Continue holding the "Home" button while the iPod turns on and release it only when the "Connect to iTunes" screen appears. Open iTunes, and click "OK" when the recovery mode alert appears. ITunes will restore your iPod back to factory settings. You'll be able to sync it with iTunes to recover the data you lost during the restore, provided you have synced with iTunes in the recent past. Check Liquid Contact Indicators b> All iPods manufactured since 2006 have built-in liquid contact indicators. If your iPod has been in contact with liquid, this could be the source of your problem. You can check whether the liquid contact indicators have been triggered by looking straight down the headphone jack on your iPod. If you see red or pink at the bottom of the headphone jack, your iPod has been in contact with liquid, and this is likely the cause of its malfunction. Contact an authorized Apple repair center to inquire about whether a repair is possible. Such repairs aren't covered under your iPod's warranty. iPod touch: Hardware troubleshooting http://support.apple.com/kb/ts2771 iOS: Unable to update or restore http://support.apple.com/kb/HT1808
Apr 13, 2013 | Apple iPod touch
My dell demension E521 is giving me a "alert system battery low" message. Any suggestions?
Check the batteries voltage and check to see if the battery is being supplied charge voltage when the computer is off. If both these are good then your low battery message is in error. No charge voltage would mean faulty charger and low battery voltage would mean faulty battery.
Dec 15, 2012 | Dell Dimension E521 PC Desktop
Tomtom still charges but traffic receiver stopped working
I'm using the TomTom Go 730T - I think this is the latest and the last TT with Traffic because TT stopped supplying this option. I'm having the same problem from time to time but a reset helps. Just press the Reset button and after restarting the traffic option is back. Janos
Jul 09, 2010 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Fully charged put on cradle fatal alert/fatal exception/reset
the lightning bolt is normal ..its telling you the battery is being charged .. if you get an error code or if the unit quits working then you can do a reset or a "hard reset" ... the hard reset erases everything and will restore the unit to factory conditions .. to do a reset .. unscrew the top of the stylus .. that gives you a probe to push the reset button on the back (top) .. if you hold the power button in while you do a reset then it gives you a choice to "erase everything" .. if you accept then thats a hard reset ... if everything else fails .. do a hard reset .. you can do all this while its on the charger so if you have a bad battery that wont matter .. if the battery wont hold a charge then it can be replaced ..
Sep 03, 2009 | Palm m515 Handheld
I have a First Alert HSS300 10-zone Wireless Alarm System. After about 23 hours or so, it starts to beep every few seconds. We press the ESC button to stop it. It does this every day. Today I must have...
Please try looking at the keypad to ascertain what zone is in trouble. It sounds alot like low battery indicated from a transmitter(s). Change all the batteries and then hit reset
May 29, 2009 | First Alert Home Security
Tire pressure reset will not reset
Labatche822,
The process for resetting your Tire Pressure Monitor (TPM) is below.
Good luck, let me know.
Regards.
To reset (calibrate) the system:
1. Turn the ignition switch to RUN.
2. Press the GAGE INFO button on the DIC until
TIRE PRESSURE appears on the display.
3. Press and hold the DIC RESET button for about five
seconds. After five seconds, the display will show
TIRE PRESSURE RESET. If TIRE PRESSURE
RESET does not appear on the display after about
five seconds, see your dealer for service. After you
release the DIC RESET button, TIRE PRESSURE
NORMAL will appear on the display.
The system completes the calibration process during
driving. During the first 10 to 25 miles (15 to 40 km) of
driving, the system will not alert you if a tire is high or
low. After 25 to 100 miles (40 to 160 km), the
system will only alert you about pressure differences of
12 psi (85 kPa) or more. After about 100 miles (160 km)
of driving, the system will alert you if one tire is
10 psi (69 kPa) different from the other three tires.
May 04, 2009 | 1999 Buick Park Avenue
Low Tire Pressure Alert won't Clear
2 ways disconnect the battery for about 5 minutes or hook up an obd II and erase the codes
Mar 22, 2009 | 2002 Chevrolet Monte Carlo
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Freezes due to low storage space alert
does your phone have memory card inside? if so try to remove card and try again. post results. Cheers
Aug 24, 2007 | Motorola Mobility Q
PEAK 450 Plus Portable Power System Logo
269 people viewed this question
Top PEAK Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a PEAK Computer and Internet Expert? Answer questions, earn points and help others
