go to amazon.com, your account, in amazon wallet click manage payment methods. You should see a list of all cards you registered. You may be showing an expired date. click arrow at right end of box to open info about that method. make corrections and click save. problem should be fixed.
Noretta,
Manage Your Fire & Kindle Payment Settings
Manage your content and Devices.
From Settings, select Edit Payment Method below Digital Payment Settings.
Select the desired credit card information, or add a new card, and then click Continue.
Enter the desired billing address, and then click Continue. You will be taken back to theDigital Payment Settings page where you can view your edited 1-Click payment method.
Follow the link below labeled "Help Search Results". It will take you to Amazons help site and give you the same instructions as above but will ask you to log into your account so you can actually do the above process without have to search around for the correct links.
From Settings, select Edit Payment Method below Kindle Payment Settings.
Enter the desired billing address, and then click Continue. You will be taken back to the Kindle Payment Settings page where you can view your edited 1-Click payment method.
Go to account settings. Select manage payment methods. Should be able to add or remove card. Contact Amazon at. [email protected] If you have any problems. Ellen
You need to change the number on the Amazon site. Go to Amazon, your account, Manage payment options, will probably ask you to verify log in info, Click on Add payment method, You MUST set new card as default. That may be what you missed. I did it the last time I changed mine. There should be an option to delete old numbers.
