If you have taken a lot of MOD video with your JVC, Canon or Panassonic camcorders and you want to play your MOD files on your new iPad, you will need a
Mac MOD to iPad converter to convert MOD to iPad supported video formats because iPad does not support MOD video format.
According to Apple’s official site, The supported video formats by iPad are the following:
1. m4v, .mp4, and .mov formats (H.264 video up to 720pt 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
2. MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
3. Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file form
Complicated, right? But no worries, Doremisoft MOD to iPad converter Mac is the perfect tool to convert MOD to iPad. This application provides preset profiles that you can choose to directly convert MOD to iPad without having to study the confusing parameters by Apple. And it lets you convert MOD files from all sorts of MOD camcorders such as Panasonic SV AV100, Canon MOD Camcorders, JVC and Panasonic etc to iPad video formats.
Doremisoft Mac Mod to iPad Converter can easily
convert MOD to iPad Mac with just a few simple and intuitive steps as follows:
Convert MOD to iPad on Mac Step 1: Add MOD files Click the "Add File" button to browse your Mac hard disc and add the MOD files you want to convert to iPad. You can either double click a file to add it or select it and click on "Open" to add it.
Convert MOD to iPad on Mac Step 2: Select the output format for your iPad
Click on the small arrow on the very right of the Profile field to open the Profile drop-up list, and you will see all the preset profiles that are made easy for you to select the output formats to convert MOD
files. Move your mouse cursor to "HD Video" and select the "Quick Time MOV" profile.
If you want all added MOD files to be converted to one format, you can just check the "Apply to all" option.
If you want to edit your MOD files before converting them, you can click here to see
how to Edit MOD files on Mac
Convert MOD to iPad on Mac Step 3: Start the conversion
After you are done with the above steps, now you can just click on the Start button to start converting your MOD files. Now you can just relax, stretch your arms and wait till the conversion is finished.
Then, you can just put the converted files on your iPad!
