Samsung Galaxy Tab 7.7 P6810 16GB Wi-Fi Only Light Silver Android v3.2 tablet Logo
A
Anonymous Posted on Feb 11, 2015
I am having a problem with the Samsung Galaxy light holding a charge. Are other people complaining about it too.
My phone will not charge. What could be the problem be??
Bill Boyd
Level 3:
Top Expert:
  • Samsung Master 53,816 Answers
  • Posted on Feb 11, 2015
Bill Boyd
Samsung Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11926207
Points
172802
If the battery will not charge there are possible explanations
that you recharge the battery before it is run completely down and now it has a memory level that it will not charge past
the light or camera is being used excessively
the unit is left switched on when not in use
trry replacing the battery with a new one
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Why is my d2 ipad frozen
I'm sorry but do you have an iPad or an Android Tablet? Android won't run on an iPad as it uses iOS operating system not android.
9helpful
3answers
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
32helpful
2answers
The screen has frozen in e mail and i cannot switch off or move to another function or do anything
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
