Apple - iPad Air 2 Wi-Fi 64GB Logo
A
Anonymous Posted on Feb 11, 2015
How do I delete vpn from my apple ipad air 2?
I have gone to settings, general, vpn, vpn configuration. but cannot find a "delete" button anywhere.
ChrisChris70
Level 2:
  • Expert 31 Answers
  • Posted on Feb 11, 2015
ChrisChris70
Expert
Level 2:
Answers
31
Questions
0
Helped
21430
Points
106
Do what you have done but when you go to VPN Configuration you should see a Blue i in a circle tap in on that icon. You should then see the settings for the VPN, at the bottom you will see Delete VPN click on that.
Cannot access face book
1. Delete the Facebook keyword in gfwinterinterceptor
2. Use VPN to access Facebook.
3. Close the VPN and add the Facebook keyword in the gfwinterinterceptor
tip
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
How can I remove a previous owners Apple ID from an iPad?
You need to either connect the iPad to iTunes and select "set up as new iPad" or you could also reset your iPad by opening settings/general/reset and choose "reset all content and setings". Both ways will delete all apps and you have to purchase or reinstall them.
How do I delete browsing history on my iPad air
Just click the link below, step by step settings;
http://www.wikihow.com/Clear-the-History-on-an-iPad
5answers
How do I retrieve pictures from iPad I cloud
Password?
A thumbs up would be greatly appreciated if this answer is helpful to you.
2answers
How to empty the trash can on iPad
- there is NO trash can on any iPad.
however you can empty some hidden cache etc. and free space by making a hard shut-off.
To turn off your iPad, first press and hold the Sleep/Wake button on the top-right corner of your iPad. After a few seconds, the red "slide to power off" slider will appear. Simply swipe it to the right and your iPad will power off.
-wait about 20seconds (until the dim-lighted spinning wheel disappears) and turn it on again
empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-0.jpg empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-2.jpg empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-5.jpg empty-trash-ipad-ehncqbmo5uzin3tthkqs5khp-2-9.jpg How to turn off your iPad
No App Store app on my ipad mini
Is it really gone? From the home screen, swipe down from middle of the screen to show iPad search. Type "App Store" in the search box. Scroll down to Applications section. Is App Store there? If so, it's on your iPad - perhaps dragged into a group somewhere.
If not, plug your iPad into the desktop Mac or PC you're using to sync. Select the iPad in the left column and click the Apps header. Scroll the list until you find the App Store app. The button should say "Install". If so, click it, then sync your iPad.
10answers
How to delete VPN from my iPad
To delete vpn from you ipad you can simple go to Settings > General > VPN. Here you will see all the vpn connections created on your device. Here you can delete it. You can review detailed instructions here: Sahrzad VPN How to Setup Guides
14helpful
2answers
How to empty trash on ipad
When you hold down on the app icon and it shakes with a little x in the left corner, that deletes an app. Once an item is deleted that is it. There is no trash can like on a mac.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
