I have a telefunken 7jc tablet that wont turn fully on when it turns on it kind of freezes where it says telefunken and doesn't want to go any further can someone please tell me what to do to fix it?
I used my tablet yesterday and last night I charged it and this morning when I wanted to use it it freezes when it turns on at telefunken. what can I do to fix this problem its urgent?
It sounds like there may be a problem with the battery or charging system of your Telefunken 3g tablet. Here are a few things you can try to troubleshoot the issue:
Make sure that you are using the correct charger and cable for your tablet. If you are unsure, check the manual or contact the manufacturer for recommendations.
Try a different power outlet to see if the problem is with the outlet or the charger.
Check the charging port for debris or damage. Clean out the port with a soft-bristled brush or compressed air, and make sure that the charging cable is securely plugged in.
If the above steps don't work, try a factory reset of your tablet. You can do this by holding the power button and volume down button at the same time until the device turns off. This will erase all data on the device, so make sure to back up any important files before doing this.
If the problem persists, it may be a hardware issue and you should consider taking the tablet to a professional for repair or replacement.
Please note that these are general troubleshooting steps and the solution may vary depending on the specific model of your tablet. Also, if the tablet is under warranty, contact the manufacturer for assistance.
Hi Lesy, let the tablet run out of power or more to the point make it run out of battery then wait 6 hours then fully charge it before turning on. Cheers Greg.
THE best way to fix your problem is go to the shop when you buy you'r tablet. and kindly ask the assistant to help or go to this website...http://www.urlidea.com/www/telefunken.com.html
