On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Does your M foot switch work on the Fender? If you know how to use a multimeter you could check continuity by putting meter leads on plug of M foot switch(1 on tip, 1 on sleeve ) You should see a change in the multi meter when you depress switch. If so switch is good. Another easy test is with cap off a spare 1/4 plug -plug it in to foot switch jack.put a alligator or some such metal clip or wire and join(called short or shorting) the two inputs . If connecting and unconnecting results in switching then the foot switch is suspect. One fairly common thing is that foot switch and input jack are often sautered straight to a circuit board to save $ on production cost. Used to be all point to point where a wire was attached to 1/4" input and then wire went to circuit board or tubes. The wire has give, but not so with direct wiring to board. So the nut holding the 1/4" amp input gets loose(doesn't have to be loose for the following to happen) and a pull on the chord causes a break in the soldier and thus a break in the sound chain. Sometimes it will work intermittingly by putting a little pressure left, right, up or down on the plugged in plug. If so, it's the input jacks connection to the amp. If not it still could be that because putting pressure on plug may not be sufficient to affect a temporary reconnection. Since switch(the new one you made)works on Fender, but not Marshall I suspect the jack or foot switch circuitry past the input jack. If using some of the above the above tests leads you that direction,remove housing(unplug a/c power 1st ) inspect jack,wiggle it slightly see or feel a break then resodier from back side. You should be able to use the soldier already present without adding extra.
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
MOST of these small amps are so SIMILAR to the competitors that you can get the users manual for one and use it for another. They are not as the saying goes, "rocket science".
That being said, try for instance the Fender Frontman manual. Here is a site for download:
You will find that even the scematic diagrams are quite similar between the brands. Let's face it, they can't re-engineer much as there is little profit.
MOST of these amps use one of the TDA family of chip audio power amps.
