Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
New refrig 1 year old and it runs constantly. what can I do to correct this problem
No idea what to do just keeps running
    New Friend:
  • 3 Answers
If the freg make more ice the problem is th thermostat but if the freg run without good cooling thats mean you micro-gas leakage
Posted on Feb 12, 2015
Anonymous
SOURCE:
Blower keeps running after a/c has reached set temp
is the fan on auto? does the unit shut off if you remove the tstat display off its subbase?
Sep 30, 2018 | Heating & Cooling
Hi I have a 1985 nissan patrol l28 motor when I turn the engine off it keeps running any ideas why ??
If it "tries" to stay running with key off, check the fuel cut solenoid on the carburetor. If it actually keeps running, the ignition switch may be bad.
Feb 27, 2015 | Nissan Cars & Trucks
2003 Dodge Durango (5.9L V8) won't stay running unless you keep your foot on the gas.
Check temp sensor and TPS, throttle positioning sensor.The power control module,"pcm.is a possible thought.Just check all connections. It is always a good idea to spray WD 40 or equivalent in the connections.
Feb 11, 2013 | 2003 Dodge Durango
Hi my McCulloch mac 70 keeps loosing power,I have changed the fuel filter,spark plug and air filter the mixture is right but still won't run right,any ideas?many thanks Barrie.
Check the muffler for any type of obstruction first. Then I would check the diaphragm in the carburetor to make sure it isn't starting to stiffen up. If that doesn't help it may be that it is just old and tired
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 16, 2013 | Garden
My 1994mazda bravo keeps running hot. I've put a
run engine from cold with rad cap off and see if it pressurises ,as its so old i suspect a failing head gasket and its due for renewal .
Nov 29, 2012 | Cars & Trucks
Datsun 180b wont keep running
Replace the ballast resistor on the coil.
Mar 19, 2012 | Datsun 1600 Cars & Trucks
Up to how many miles the engine can keep running
Depends on maintenance and use. Some chevys go 500000 miles with no issues some go 150000. Have a mechanic check the vehicle to get a good idea of its condition.
May 09, 2010 | 2000 Chevrolet 3500
I had my car running and it quit and it would keep starting and quit and know it won't start, any idea's what it could be?
It is the crankshaft sensor. Had a car that would start and run very rough then it would quit, Would start and just keep quiting.
Mar 01, 2010 | 1996 Oldsmobile Cutlass Ciera
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Tricity bendix keeps turning off !!
assuming you still have power to machine, it could be that the main circulating pump has a thermal overload in it which is tripping off. can you give me more detail?
Apr 23, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
76 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
