Those machines come with shipping bolts that hold the drum to the frame when it is shipped. This ensures that nothing gets slammed around when it is moved. Without those in place, there is a chance that the shock absorbers and springs that align the drum when it is on CAN COME loose and then you have a banging noise when the drum spins.
The loud banging noise in the spin part of the cycle is usually caused by bad drum bearings. The repair is carried replacing the bearing at the back of the drum. Such kind of replacement is carried disassembling most of the appliance to reach the back of the tub. If you have not done similar repairs before it may be better to call a technician ringing the Asko support number listed on the owners manual.
sounds like main drum bearings not common but if the bearings are worn you get the banging noise and as it slackens the drive belt you get screeching noise as the belt slips.
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
if i were you fist of all open door then you will see the silver drum on the inside lift the silver drum upwards from the top of it and if you feel a knocking sound then the bearings have worn out expencive to replace them,as sometimes you have to have a complete new drum.rgrds,paul
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out, believe it our not even washing machines have shockers to dampen the movement of the drum spinning
