The four wire 220 twist lock receptacle Two hot wires, one neutral, and a safety ground. Depending on your generators setup the neutral and ground are bonded as one; unless, it setup for a floating neutral.
You would normally connect the two hots and neutral. and leave the ground open on the four prong twist lock plug. Just make sure the compressor is earth grounded on its end.
